Hi, have a problem with the applicability of my IDS in regards to IsExternal in Pset_WallCommon.
If I use this IDS that hast two specifications each with am applicability of the name "Ortbetonwand" and one with "IsExternal=TRUE" and the other with "IsExternal=FALSE", Bonsai does apply both specifications only to objects with "IsExternal=TRUE". Solibri does apply these correctly with the same IDS so I assume its a Bonsai/IfcTester-bug.
Tested with 0.8.0 in Bonsai and ifcOpenShell Command line.
Is it just me that has this problem? it seems to basic to be a "regular" bug.
i would really like to use Bonsai for my IDS-reports, as I have to do a lot of them for a big project.
<ids xmlns="http://standards.buildingsmart.org/IDS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://standards.buildingsmart.org/IDS http://standards.buildingsmart.org/IDS/1.0/ids.xsd">
<info>
<title>TEST</title>
<author>xxxxx@xxxxx.xxx</author>
<date>2024-10-30</date>
</info>
<specifications>
<specification name="ApplicabilityTEST" ifcVersion="IFC4" description="Test of Applicability">
<applicability minOccurs="1" maxOccurs="unbounded">
<entity>
<name>
<simpleValue>IFCWALL</simpleValue>
</name>
</entity>
<attribute>
<name>
<simpleValue>Name</simpleValue>
</name>
<value>
<simpleValue>Ortbetonwand</simpleValue>
</value>
</attribute>
<property dataType="IFCBOOLEAN">
<propertySet>
<simpleValue>Pset_WallCommon</simpleValue>
</propertySet>
<baseName>
<simpleValue>IsExternal</simpleValue>
</baseName>
<value>
<simpleValue>TRUE</simpleValue>
</value>
</property>
</applicability>
<requirements>
<property dataType="IFCLABEL" cardinality="required">
<propertySet>
</propertySet>
<baseName>
<simpleValue>FireRating</simpleValue>
</baseName>
</property>
</requirements>
</specification>
<specification name="ApplicabilityTEST2" ifcVersion="IFC4" description="Test of Applicability 2">
<entity>
<name>
</name>
</entity>
<attribute>
<name>
</name>
<value>
</value>
</attribute>
<propertySet>
</propertySet>
<baseName>
</baseName>
<value>
<simpleValue>FALSE</simpleValue>
</value>
</property>
</applicability>
<requirements>
<propertySet>
</propertySet>
<baseName>
</baseName>
</property>
</requirements>
</specification>
</specifications>
</ids>
Thanks!
