IfcDoor disappears in aggregate Ifcwall after moving
  1. A
    Please try moving door...then regen with shiftG. Door will disappears...where am I wrong?
  1. T
  1. A
    Pardon, it's my first post
  1. T
    no problem... ask away.
  1. A
    No one has experienced this issue?
  1. S
    hi @Amerigo
    In your .ifc file door and wall are in an IfcElementAssembly and, if you don't already know it, moving the door requires entering [tab] into it before doing it. Could that be the cause of the "disappearance" ?
    To show it back select the door in the Outliner go to Geometry and Materials > Parametric Geometry > Door and click on the + next to "No door found"
    ciao
  1. T
    Also, don't put the door 'in' the aggregate. If you do, it's voiding itself, so to speak. see video.
  1. A
    @steverugi @theoryshaw It works!...Many thanks. Ciao
