P_BOUNDEDVALUE: how to set the range to a custom PSET property?
  1. M
    Hi there!
    I wanted to use a range for a value so I've set P_BOUNDEDVALUE in PSET template.
    ! When I add this custom PSET to my object the propeties are missing.
    ! Am I doing something wrong?
    Thank you very much!
  1. M
  1. M
    @Moult I made a script to set these values.
    import bonsai.tool as tool
    import ifcopenshell
    import ifcopenshell.guid
    import logging
    import sys
    logger = logging.getLogger("Pset_mod")
    logger.setLevel(logging.DEBUG)
    stream_handler = logging.StreamHandler(sys.stdout)
    stream_handler.setFormatter(logging.Formatter("%(asctime)s - %(levelname)s - %(message)s"))
    logger.addHandler(stream_handler)
    ifc_file = tool.Ifc.get()
    if not ifc_file:
        raise Exception("IFC file not loaded.")
    elements = ifc_file.by_type("IfcWall")
    for element in elements:
        existing_pset = None
        for rel in element.IsDefinedBy:
            if rel.is_a("IfcRelDefinesByProperties") and rel.RelatingPropertyDefinition.is_a("IfcPropertySet"):
                if rel.RelatingPropertyDefinition.Name == "DIA_design":
                    existing_pset = rel.RelatingPropertyDefinition
                    break
        owner_history = None
        if ifc_file.by_type('IfcOwnerHistory'):
            owner_history = ifc_file.by_type('IfcOwnerHistory')[0]
        if not existing_pset:
            existing_pset = ifc_file.createIfcPropertySet(
                ifcopenshell.guid.new(),
                owner_history,
                'DIA_design',
                None,
            ifc_file.createIfcRelDefinesByProperties(
                owner_history,
                None,
                None,
                [element],
                existing_pset
        ac_ratio = ifc_file.createIfcPropertyBoundedValue(
            'A/C',
            None,
            ifc_file.createIfcRatioMeasure(1),  # Upper bound
            ifc_file.createIfcRatioMeasure(0.9),  # Lower bound
            ifc_file.createIfcRatioMeasure(0.95),  # Nominal value
            None
        peso_specifico = ifc_file.createIfcPropertyBoundedValue(
            'Peso_specifico',
            None,
            ifc_file.createIfcMassDensityMeasure(1650),  # Upper bound
            ifc_file.createIfcMassDensityMeasure(1450),  # Lower bound
            ifc_file.createIfcMassDensityMeasure(1550),  # Nominal value
            None
        viscosita = ifc_file.createIfcPropertyBoundedValue(
            'Viscosità',
            None,
            ifc_file.createIfcTimeMeasure(50),  # Upper bound
            ifc_file.createIfcTimeMeasure(47),  # Lower bound
            ifc_file.createIfcTimeMeasure(48),  # Nominal value
            None
        new_properties = []
        for prop in existing_pset.HasProperties:
            if prop.Name not in ['A/C', 'Peso_specifico', 'Viscosità']:
                new_properties.append(prop)
        new_properties.extend([ac_ratio, peso_specifico, viscosita])
        existing_pset.HasProperties = tuple(new_properties)
    logger.info("Done.")
    This is what it looks like on blender
    And in BimVision I get exatcly what I was looking for:
    ( I don't know why it shows kg/m² instad of kg/m³ but it must be a bug of BimVision)
  1. M
    Uhm I tried to validate from buildingSMART and it looks bad :S
    Schema - Unit (occurred 1002 times)
    ⓘ Note: a high number of occurrences were identified. Only the first 10 occurrences are displayed below.
    Id  Entity  Severity    Message
    #28828  IfcPropertyBoundedValue Error   With attribute:
        <attribute Unit?: <select IfcUnit: (<entity IfcDerivedUnit> | <entity IfcMonetaryUnit> | <entity IfcNamedUnit>)>>
    Value:
        IfcTimeMeasure(48.)
    Not valid
    #28829  IfcPropertyBoundedValue Error   With attribute:
    Value:
    Not valid
    #28830  IfcPropertyBoundedValue Error   With attribute:
    Value:
        IfcMassDensityMeasure(1550.)
    Not valid
