Figured that importing DXF as IfcVirtualElement could be a way to keep a reference drawing in Bonsai Ifc file. But the problem arises when I try to draw walls using dxf as reference and the snapping kicks in and slows cursor display down to impossibly slow motion and jerking around. It actually makes no difference even if I turn snapping off completely, it is still the same.
This might be due to large size of dxf (10 000 items). But before importing I cleaned it by removing unnecessary layers and performing overkill.
Any thoughts? Should I go back to raster image references?
Edit: Of course immediately after posting this I tried to draw in other view than top view and now it works faster. So the slowdown is only on top view (both model and drawing mode).
