Getting OverallHeight from a IFCWindow
  1. M
    I wonder if somebody knows how to get OverallHeight and Width from a selected IFCWindow? I guess you first need to determine if they have these attributes. I just tried
    from bpy import context as C
     for ob in C.selected_objects:
      print (ob.OverallHeight)
    but of cource it was not that simple
  2. M
    I thought the name might be a custom property and used bpy.data.objects[str(obj.name)]['name']) but no luck.
  3. M
    Ok, I solved it kind of
    ifc_data = IfcStore.get_file()
    windows = ifc_data.by_type('IfcWindow')
    for window in windows:
        print(window.OverallHeight)
        print(window.OverallWidth)
    gives me the height and width of all windows but the problem is that I want the user to select the windows like
    import bpy
    selection = bpy.context.selected_objects
    for  obj in selection:
        if obj.name.startswith("IfcWindow"):
            print (obj.OverallHeight)
    but then I get AttributeError: 'Object' object has no attribute 'OverallHeight'
  4. B
    Hi @Max, I think the problem is that you are trying to access the IFC property through the Blender Object. You have to get the IFC entity from the Blender object first. I haven't fully tested it, but maybe this will work:
    import bpy
            ifc_entity = tool.Ifc.get_entity(obj) #gets the Ifc Entity from the Blender object
            print (ifc_entity.OverallHeight)
  5. M
    Thanks a lot, I suspected something like this. For some reason tool.Ifc.get_entity(obj) gets "None" and then AttributeError: 'NoneType' object has no attribute 'OverallHeight'
  6. B
    I tested with two different files, and it worked for me. Maybe it's something with the file?
  7. M
    I feel like a complete idiot. I downloaded the IFC from this forum but I guess it was too experimental. With a typical Revit file it worked fine. Thanks for all your help.
