[BlenderBIM] How to create a simple StructuralAnalysisModel?
  1. S
    Hello,
    I'm new to blenderBIM and i want to create a simple Structural analysis model. For example a frame structure with a line loading, supports and maybe a hinge.
    I would be very thankful for some guideline on how to start.
  2. T
    Would this file help you get started?
    @Jesusbill might have some more insight, as well.
  3. T
  4. S
    @theoryshaw thank you! That was helpful.
    I've managed to create Beams, hinges/connections and supports. However, how do I add a load e.g. on a beam?
  5. T
    ¯\(ツ)/¯
    This is where i bow out. :)
  6. T
  7. T
  8. T
  9. T
    You know I couldn't stay away. :)
    Found this.
  10. J
    Hi @smr02 at the moment it is not possible to assign loads, load cases and load combinations; the development was done up to the model definition point (create model + elements + connections) with Dion, then some initial work on creating loads and load assignment was done but it was not completed (thus the "ghost" icons in the screenshot of @theoryshaw :D) and this was more than a year ago and before the refactoring of BBIM. Unfortunately I haven't got the time until now to work or further support this process, but the will to conclude it is definitely there.
    The good news is that from this month I can start allocating some time on this, so hopefully we can bring it forward and conclude load, load cases and load case combination assignments.
    PS: Thanks @theoryshaw for the shoutout
  11. E
    Hi @Jesusbill, I am also very interested in creating a StructuralAnalysisModel using Blender BIM. Is it possible to assign loads now? I also have another question. How to assign IFCStructuralCurveMember to IFCBeam (something like IfcRelAssignsToProduct) in Blender BIM? Thank you for your help!
