@bruno_perdigao
This total method is nice, could there also be an option where you could set the dimension of the total length of the array? I think I already saw it quick in demo in the dropdown... Maybe you are already working on it?
@bruno_perdigao
@Coen
Maybe it wasn't clear in my post, but the idea of the "total" option is that the value of the input is the total length of the array. In the example above, "12m" means the distance between the first and the last cube (when "total" is selected). If "increment" is select, "12m" will be the distance between each cube (which is the default behavior right now). Is that what you mean?
@bruno_perdigao both of those look like awesome additions! Please go for it!
sweet PR!
The array function is fine. Is there any way to do something like native blender Possibly An ifc object array followed on a curve ?
