FreeMVD: Extrusions_Voids
  1. T
    Ongoing Results:
    https://gitlab.com/osarch/FreeMVD_WorkFlow/-/blob/master/IFC_roundtrip_specifications.md#extrusions_void
    Test Files: https://gitlab.com/osarch/FreeMVD_WorkFlow/-/tree/master/Specifications_Test_Files/Extrusions_Void
    FreeMVD: Are experiments on how well certain objects roundtrip in/out of various BIM applications. We are always looking for volunteers, from other BIM applications, to add their results to these tests. If you can participate, ping @yorik or @theoryshaw and they can give you Gitlab push privileges.
  2. M
    Just a note on this - I think this test should be renamed to extrusions with inner boundaries, as there are two ways to create voids: with a voiding object, or with an inner boundary, and your tests is with the latter.
    This is code in the BlenderBIM Add-on to deal with this, but I haven't yet refactored it to work with the new native element import feature :) It will be a natural next step to support this!
  3. T
