[IfcOpenShell-Python] How using the ObjectPlacement in ifcwall?
  1. M
    So what i am trying to do is:
    There is one representation in the ifc file, and i want it to use for two ifcwall. However i want to add two different ObjectPlacement so the two ifcwall don't overlap.
    Right know i have this:
    https://github.com/Martin15135215/git_ifc_test/blob/main/test_object_placemnt.py
    after adding the ObjectPlacement to the wall, i did not see any difference., when i open it in a ifc viewer
  2. M
    i saw my mistakes, it did function, however this function
    created for length in Millimeter, so i did not see a great difference ?‍♂️
    Now in metre:
  3. M
  4. C
    What's the difference between:
    model = ifcopenshell.file()
    and
    model = ifcopenshell.api.run("context.add_context", ifc_file, context_type="Model")
  5. B
    The first is the entire IfcOpenShell IFC model, the second is the "Model" context (note the capital M)
  6. M
    BIM data is different to 3D - in 3D 1 object has 1 geometry. In BIM, 1 object may have N geometry (e.g. a 3D door, a 2D door swing, a door clearance, a 2D door elevation, etc). To distinguish between these different geometries and when you should use which geometry, IFC has the concept of a "Context", the "Model" context contains all 3D geometry, like the 3D door (via the Model/Body subcontext) and the door clearance (via the Model/Clearance subcontext).
  7. Z
    It doesn't have much to do with the theme, but it's similar.
    How do I identify the contact surface between two distinct elements that touch and create a solid object, such as a wall, with dimensions of that
    contact plane and thickness of 1mm?
    For example, a column and a wall. Identify the contact plan between them. Like the imagem below:
    In blue the wall and grey the column
  8. Z
    One mor image to explain
