[IFC] Why is IfcElementAssembly under IfcElement instead of IfcSpatialElement?
  1. M
  2. B
    I suppose that an Element Assembly is a thing made up of other things, whereas a Spatial Element is a space that can contain things or other spaces
  3. M
    Because an IfcElementAssembly is an IfcElement.
    • Spaces <-- IfcRelAggregates --> Subspaces, i.e. spaces are made out of subspaces.
    • Elements <-- IfcRelAggregates --> Subelements, i.e. elements are made out of subelements.
    • Spaces <-- IfcRelContainedInSpatialStructure --> Elements, i.e. Spaces contain elements
    Notice aggregates are used when the same type is made out of smaller things of the same type. In contrast ContainedIn relationships are used between spaces (i.e. you can't touch it, just a virtual imaginary bounds) and elements (i.e. you can touch it, buy it, build it, etc)
  4. M
    So for example:
    IfcProject <-- IfcRelAggregates --> IfcSite <-- IfcRelAggregates --> IfcBuilding <-- IfcRelAggregates --> IfcBuildingstoery <-- IfcRelContainedInSpatialStructure --> IfcElementAssembly <-- IfcRelAggregates --> IfcBuildingElementProxy
    Did i understand it correctly?
  5. M
    Yes.
