Topologic Mirror surface normal
  1. M
    Hi everyone, quick question.
    Is there a way to mirror or flip a surface normal with a topologic node in dynamo.
    I am now getting the surface out of the topologic graph and putting it back in later.
    Kind regards,
    Piet
  2. T
    @topologic might know.
  3. T
    Sadly in Dynamo there isn't a direct method to reverse a topologic face AFAIK. Instead here are the manual steps that are needed:
    1. Get the Wire subtopology of the face (assuming a simple face with no holes for now) Face.Wire.
    2. Get the vertices of the Wire (These will be ordered) Wire.Vertices
    3. Reverse the list of vertices (Use Dynamo to reverse a list)
    4. Re-build the wire from the reversed list of Vertices (I am hoping there is Wire.ByVertices. I don't remember. If not, do a loop to build Edges from consecutive vertices and then do a Wire.ByEdges.
    5. Re-build the Face from the Wire (Face.ByExternalInternalBoundaries). It should now be pointing in the opposite direction
    You could do all this in one custom python designscript code.
  4. M
    Thank you for your response. I will try the solution above.
    Kind regards.
  5. T
