by ShellNotClosed on 13 Jan 2023, edited 16 Jan 2023
Hello,
i got an ifc file from an architect (Archicad) and there are i few Objects where the shell is not closed. I found these with an other software and want to fix this.
Is there a possibility in BlenderBIM to
a. detect this errors and
b. fix these (with ease ;))
here a few examples:
Thanks for answers!
by theoryshaw on 13 Jan 2023, edited 13 Jan 2023
Can you share the ifc file? If not, can you share an pared-down version of the IFC file, one for example, that has only the errors in it.
This is not the OG file, but all 16 objects with errors.
G
by Gorgious on 16 Jan 2023
FWIW in Blender there is an addon called 3D-print toolbox that is shipped with the vanilla download. If you activate it you'll get a handy panel in the right hand side region of the viewport that will let you check the mesh, and there is a "make manifold" button that might help you.
by ShellNotClosed on 16 Jan 2023
Thank you for the respond. It didnt work for me unfortunately.
