@Coen said:
How can I retrieve classification of an element?
Maybe something like this?
def get_classification_code(self, context, ifcproduct, ifc_version):
#Classifications of an object may be referenced from an external source rather than being
#contained within the IFC model. This is done through the IfcClassificationReference class.
#ClassificationRefForObjects',
assembly_code_list = []
if ifcproduct.HasAssociations:
if ifcproduct.HasAssociations[0].is_a() == 'IfcRelAssociatesClassification':
if ifcproduct.HasAssociations[0].RelatingClassification:
#for IFC2x3
if ifc_version == 'IFC2X3':
if ifcproduct.HasAssociations[0].RelatingClassification.ItemReference:
assembly_code_list.append(ifcproduct.HasAssociations[0].RelatingClassification.ItemReference)
#for IFC4
if ifc_version == 'IFC4':
if ifcproduct.HasAssociations[0].RelatingClassification.Identification:
assembly_code_list.append(ifcproduct.HasAssociations[0].RelatingClassification.Identification)
if ifcproduct.HasAssociations[0].is_a() == 'IfcRelAssociatesMaterial':
for i in ifcproduct.HasAssociations:
if i.is_a() == 'IfcRelAssociatesClassification':
#for IFC2x3
if i.RelatingClassification.ItemReference:
assembly_code_list.append(i.RelatingClassification.ItemReference)
#for IFC4
if i.RelatingClassification:
assembly_code_list.append(i.RelatingClassification.Identification)
No module named 'ifcopenshell.util.attribute
I don't know about that module, maybe @Moult has better ideas then my code.
Or something like this. An object can contain multiple classifications. Only tested for IFC2X3TC1
def get_classifications(element) -> list:
"""Get classification code (ItemReference)."""
classifications = []
for association in element.HasAssociations:
if association.is_a("IfcRelAssociatesClassification"):
item_reference = association.RelatingClassification.ItemReference
classifications.append(str(item_reference))
return classifications
