Export a subset of the objects to an .ifc
  1. B
    What is the 'best-practice' in order to export a subset of the .ifc file imported into Blender using BlenderBIM?
    Is is possible to kind of simply select some (.ifc-)objects in the viewport, and export only those (with same position in the IfcProject as when imported into Blender)?
    BR Sondre
  2. B
    Something similar can be done checking "Enable Advance Mode" when loading a file
    After selecting the file to load you can use a "Filter Mode "
  3. B
    But I want to do something similar for an export, is that possible?
  4. B
    Sorry, should be this:
  5. B
    Ah, I knew I had seen IfcPatch somewhere in BlenderBim, thanks! ?
