I am using Blender quite often to edit geometry based upon BIM-models, usually IFC, Speckle and dotBIM but find the interface difficult since the facades tend to hide a lot of the information and it is difficult to get a grasp of large models. I have tried to use hide/show, use section cuts and change transparency but it still difficult and I wonder what commands, tools, settings and plugins you use?
Otherwise a well organised model is the most useful tool for me (even though I fail at that often)
When importing sketchup and revit ifc's I often recategorise the groups, classes,etc aswell because it comes in quite messy, but only as I am going through it not all at once.
It's a slow process but it works out when you get used to it
by theoryshaw on 19 Jan 2023, edited 19 Jan 2023#
Cool. That now begs the question, if selection IFC groups can be linked from one file to another? Similar how you import assets via the IFC Project Library.
@vpajic, Would be sad if we couldn't import these glorious selection groups into other files. ;)
G
by Gorgious on 20 Jan 2023, edited 20 Jan 2023#
Since the query syntax is a character string (AFAIK), we could implement a way to selectively store them in the addon properties so they are available in all blend files. It would need to also store the query name or additional information I guess, to remember what it does ?
In my opinion this function is the answer to all the questions about scene organisation and more. It's a solution I proposed years ago for archicad and I'm really excited we have it in bbim now.
All we need now is a better ui and we can use it to control displaying of construction phases, levels, renovations and much more.
