I've just discovered that there is a IfcElement called IfcVoidingFeature. I want to use it to add holes or chamfers.
I can add it as void to a Wall, but it's not getting subtracted.
You need to
Hope that helps, it's not too straightforward at the moment but hopefully we can find a simpler way in the future
@Ace you should do videocasts... will save you a lot of work. :)
Thank you, @Ace!
I've imported a geometry from a different program (Rhino) that i want to add as void. Is it possible to use a existing geometry as the void?
Or this: https://www.screentogif.com/
Hahaha I like screenshots, especially for simple things like this, but noted ;)
@smr02 said:
Thank you, @Ace!
I think sooo..... YES
Just select the 'opening' object (from rhino) then the wall and hit apply void
That's quite cool
as @Ace said yes.
videocast:
If you use windows, l like to use https://getsharex.com/ for screencaptures
Thanks for explaining this. Very Useful.
Is it possible to edit the void later to re-adjust the size or shape of the void?
Thanks.
Thanks.
Just found it.
Use toggle openings (voids) 'option/alt O' or 'Void' under Mode in the toolbar to turn on the void, and then tab to edit.
