Detect non-manifold geometries using IfcOpenShell and OpenCascade
  1. M
    Sometimes, IFC models can contain shape representations that are not manifold. Is there a way to detect them using IfcOpenShell and OpenCascade ?
    An example of shape that is not manifold
  2. M
    @aothms might know.
  3. A
    We have an implementation here in C++ https://github.com/IfcOpenShell/IfcOpenShell/blob/v0.7.0/src/ifcgeom_schema_agnostic/base_utils.cpp#L91 (which you can adapt to pythonocc if needed).
    The bigger problem than (pure-topological) non-manifoldness is self-intersections I'd say. By default we already do a check on face boundary and extrusion basis self-intersections https://github.com/IfcOpenShell/IfcOpenShell/blob/v0.7.0/src/ifcgeom_schema_agnostic/wire_utils.cpp#L376 Which may lead to non-manifoldness in the shell, but self-intersecting faces is a more severe problem.
    Hope that helps a bit. There's quite a few geometric problems typically in ifc models. We're also checking some aspects of those in validate.buildingsmart.org (https://github.com/buildingSMART/ifc-gherkin-rules/blob/main/features/GEM001_Closed-shell-edge-usage.feature)
  4. A
    Are there models that illustrate the different cases of non-manifoldness ? I can try to generate and provide some myself
    Not exhaustively, I think that would be a great idea, also when considering the different geometry modes of IFC, IfcManifoldSolidBrep, IfcTriangulatedFaceset IfcTesselatedFaceset IfcAdvancedBrep etc.
    topology module of OCCUtils
    I personally don't use it because I'm familiar enough with the main OCC API..
  5. M
    A minor note that the built-in 3D print add-on in Blender also has a manifold geometry check, but that might not be what you're looking for.
  6. M
    Regarding the first scenario, are you considering using the topology module of OCCUtils ?
  7. B
    • import in FreeCAD
    • convert to a FreeCAD Mesh object
    • use Analyse Tools of FreeCAD Mesh to find and maybe even repair the geometry (it has special tool to find nonmanifolds)
    • convert back to a FreeCAD Part object
    • export back to IFC
    Is what I have done very often on corroupted geometry.
    All this might be possible in Python too.
    cheers bernd
