[BlenderBIM] Compile for FreeBSD
  1. A
    Hi everyone.
    Is there a way that I can compile BlenderBIM on FreeBSD? I have tried the Linux version but it gives library errors. I don't think I should've done this but I also tried symlinking the libraries, and finally got stuck at libc.so.6.
  2. M
    @aothms might know.
  3. A
  4. A
    @aothms, there is already a FreeBSD port for ifcopenshell. Can this be used or do I still have to compile ifcopenshell?
  5. A
    It doesn't look promising, it would be too old:
    Broken BROKEN: error: no viable overloaded '='
    Last Update: 2022-10-20 19:13:41
  6. M
  7. A
    @aothms and @Moult thank you. I have been going through those compilation instrucations and also the Makefile I have mentioned. I guess first I should compile it myself and when it successfully compiles, then I should try to make a package file.
    For now I guess I got all the dependencies right and cmake finished successfully. I'm waiting for make.
