Turns out that BlenderBIM is my most trustful and reliable BIM Viewer.
(Not even tried to play with creation of BIM Files directly in Blender,
together with some of these Architecture AddOns so far)
Usually I use OpenIFCViewer from ODA to check or quick look at IFC files,
as it is free, fast and simple. I did not have good experiences with free
versions of proprietary BIM management/viewers in the past for several reasons,
although they sometimes offer somenice exchnge/integration in my CAD Aps.
OpenIFCViewer even finally got Apple ARM and Metal Support.
And I expected it to be reliable, as being the source of IFC Support for many
proprietary CAD/BIM Apps.
But it turned out that I more and more miss some IFC 4 tagged elements in
OpenIFCViewer. Mostly Roof objects from Vectorworks exports.
But when I try to check and open such an IFC in Blender/BIM,
every object is magically there and visible as it should be ...
I would have expected the open source project lagging behind instead.
I only had an single IFC issue in BlenderBIM once, that I mentioned as a
side note on the forum. And it was cared about, recognized as an issue
within BIM specification and therefore fixed just 2 days later.
When I upgrade BlenderBIM from time to time I usually just grabt for the
daily builds, although some tutorial videos warned but it was always a
smooth experience.
So again a big thank you for the great experience !!!
