by theoryshaw on 28 Apr 2023, edited 19 Jul 2023
Is there a way to add to... "Which IFC class should I use"
https://blenderbim.org/search-ifc-class.html
every so often, i come across common terms, that should be in this database.
Recently Millwork and Casework, which are terms used a lot, in the US anyways.
by Moult on 1 May 2023
+3 votes
"Email me" :( It's terrible, but...
by theoryshaw on 18 Jul 2023
Furnace > IfcDistributionElement
Is it possible to put this stuff in a repo?
G
by Gorgious on 18 Jul 2023
Hey for what it's worth if you have ideas you can update the dictionary there https://github.com/IfcOpenShell/IfcOpenShell/blob/963ffa39b763226839c5efd7727e7d64fefc0593/src/blenderbim/blenderbim/bim/module/root/data.py#L112-L126 and it will auto-fill the suggestions when you use the looking glass button and type in class names in the BlenderBIM addon.
Oh cool, i can add to that.
by theoryshaw on 19 Jul 2023
@Gorgious
Is there a way to format it, such that it autofills the predefined type as well?
G
by Gorgious on 19 Jul 2023
I'm sure there is a way. Would you mind adding this as an issue over on github so I can track it ?
