I have attempted to install BlenderBIM several times according to the documentation and video tutorial, but after installing, when I attempt to check the box next to the add-on to activate it, I get this error:
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/__init__.py", line 89, in <module>
refresh()
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/__init__.py", line 76, in refresh
if not Git.refresh(path=path):
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/cmd.py", line 318, in refresh
cls().version()
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/cmd.py", line 741, in <lambda>
return lambda *args, **kwargs: self._call_process(name, *args, **kwargs)
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/cmd.py", line 1315, in _call_process
return self.execute(call, **exec_kwargs)
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/cmd.py", line 1109, in execute
raise GitCommandError(redacted_command, status, stderr_value, stdout_value)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(1)
cmdline: git version
stderr: 'xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun'
The above exception was the direct cause of the following exception:
File "/Applications/Blender.app/Contents/Resources/3.5/scripts/modules/addon_utils.py", line 333, in enable
mod = __import__(module_name)
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/__init__.py", line 40, in <module>
import blenderbim.bim
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/bim/__init__.py", line 22, in <module>
from . import handler, ui, prop, operator, helper
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/bim/handler.py", line 23, in <module>
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/tool/__init__.py", line 33, in <module>
from blenderbim.tool.ifcgit import IfcGit
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/tool/ifcgit.py", line 6, in <module>
import git
File "/Users/roy/Library/Application Support/Blender/3.5/scripts/addons/blenderbim/libs/site/packages/git/__init__.py", line 91, in <module>
raise ImportError("Failed to initialize: {0}".format(exc)) from exc
ImportError: Failed to initialize: Cmd('git') failed due to: exit code(1)
Any help resolving this would be greatly appreciated.
