IfcTester - Error on IDS with classification system
  1. C
    Hi Dion @Moult,
    I'm really exited about IfcTester, discovering its possibilities and eager to implement this within my company. However, when I run my IDS with IfcTester I get this error:
    _Traceback (most recent call last):
    File "C:\Users...\PycharmProjects......\ifc_validator.py", line 42, in <module>
    my_ids.validate(my_ifc)
    File "C:\Users...\PycharmProjects....venv\lib\site-packages\ifctester\ids.py", line 118, in validate
    specification.validate(ifc_file, filter_version=filter_version)
    File "C:\Users...\PycharmProjects....venv\lib\site-packages\ifctester\ids.py", line 230, in validate
    facet.failed_reasons.append(str(result))
    TypeError: str returned non-string (type NoneType)_
    I created my IDS with the following code:
    restriction = ids.Restriction(options={"enumeration": classifications}, base="string")
    my_spec.requirements.append(ids.Classification(value=restriction, system="NL-SfB", minOccurs=1, maxOccurs="unbounded"))
    my_ids.specifications.append(my_spec)
    The IDS works on IFC's where a classification system "NL-SfB" is present, but crashes when it is not. Wouldn't IfcTester just return a failed check instead of a Traceback error? Or am I missing something?
    EXAMPLE: when passing
    BIM basis ILS - 3.6 Classificatiesystematiek
    [PASS] (149/149) *Classificatiecode.
    Applies to:
        All {'enumeration': ['IFCACTUATOR', ... , 'IFCWINDOWSTANDARDCASE']} data
    Requirements:
        Shall have a NL-SfB reference of {'enumeration': ['11.10',  ... , '90.83']}
    Cheers,
    Wout
  2. M
  3. C
    Thanks for the quick reply, much appreciated! And no I did not report the bug, but I'll keep in mind at reporting on github next time.
  4. C
    @Moult , tested your bugfix and it works like a charm, Thanks!
