by Bimlooser on 7 Jul 2023, edited 8 Jul 2023
Hi guys, i found in the building smart IDS this code:
If i'd like to export to bcf the results is it correct to change the last row as below:
**bcf_reporter = reporter.Bcf(my_ids)
report_data = bcf_reporter.report()
bcf_reporter.to_file('PathTo_SampleIDS.bcf')** ????
If i'd like to load an .xml IDS file how i can change the first part of the script?
Hope everything is clear.
Thanks in advice for your reply
by Moult on 7 Jul 2023
specs = ifctester.ids.open('/path/to/requirements.ids')
specs.validate(ifc)
by Bimlooser on 8 Jul 2023, edited 8 Jul 2023
Thanks a lot @Moult . If somone is interested below the code to create a bcf from a .xml IDS file:
import ifcopenshell
import ifctester
from ifctester import reporter
specs = ifctester.ids.open('C:\PathToFile.ids')
my_ifc = ifcopenshell.open(r'C:\PathToFile.ifc')
specs.validate(my_ifc)
bcf_reporter = reporter.Bcf(specs)
bcf_reporter.to_file('C:\PathToFile.bcf')
My workflow is:
use @c4rlosdias https://idsconverter.herokuapp.com/ tool to create IDS file.
Use the script in Blender
Visualize the results in BlenderBim loading the bcf file and for faucets that not concern IfcElements use "Ifc Tester" module inside BlenderBim that gives an Html file
AMAZING
