by theoryshaw on 18 Jul 2023, edited 5 Dec 2023
With printed floor plans, is there a way to configure 2D representation (Model/Body/PLAN_VIEW, or the like) of something like the following, so the 2D part has a fill in it, so the background (blue ifcslab in this case) doesn't show, or is covered up? Like the last image?
attached files, open Blender file first, as I used 'Calculate Shapely Surfaces' for surface fills.
by bruno_perdigao on 18 Jul 2023
I added a 2d representation to create just the rectangle with an internal face, and it worked. Don't know if it's going to work in all situations.
by Moult on 18 Jul 2023
Add this as a bug, we need to support this but I'm not exactly sure how (I need to check whether or not you can mix curves and surfaces, or if not, whether we offer an option to create a perimeter fill).
by theoryshaw on 19 Jul 2023
Sweet! Was funny, i posted this, then took a shower, and while there, thought: "I should add another context for just the fill".
Nothing like a shower for deep thoughts. ;)
Agreed... would be nice to avoid this hackery. :)
https://github.com/IfcOpenShell/IfcOpenShell/issues/3473
by theoryshaw on 3 Oct 2023
This hack doesn't seem to work anymore, as the tub now has no 'fill'.
See files, here.
by theoryshaw on 5 Dec 2023
Has anyone figured out a work around for this?
by Ace on 5 Dec 2023
It's bad and tedious but you could put a flat building element proxy in the shape of the tub, just below the tub.
Bath on a concrete slab:
Bath with a building element proxy underneath:
layout in BBim:
This is exaggerated for effect they can be 5mm above the slab and it should still work
This is less than ideal but drawings need to look right
