BB's UI: Visual feedback based on context
  1. S
    This discussion was created from comments split from: <a href="/discussion/1668/overview-of-keyboard-shortcuts-for-the-blenderbim-add-on/">Overview of keyboard shortcuts for the BlenderBIM add-on</a>.
  2. C
    @theoryshaw said:
    sounds like a great wiki page. :)
    Good idea, slightly related. Do you know how to visually represent in BlenderBIM in which context you are? It happens often I press a button and I forgot I have the BIM tool not selected.
    Is there a native Blender option to color the frame a certain color so you know you have certain tools active?
    For example, it's hardly visible I have the BIM tool selected.
    Don't know if it's just me or other users also have this experience?
  3. T
    @Coen ¯\(ツ)/¯
  4. C
    Just curious if it's possible to have a colorized edge around the viewport when the BIM tool is selected. I checked in the theme, but was overwhelmed by the options.
  5. M
    @Coen i did a little research and it seems that it can be possible to change a specific color in the ui with this command
    bpy.context.preferences.themes[0].user_interface.editor_outline = [1.0,0.0,0.0]
    In this case, it sets the "editor_outline" to red. Just change the float array following the RGB 0,1 rules with the preferred color ...
    It changes all the contour tabs but i think it could be nice ...
  6. C
    @Massimo
    Thanks, exactly what I was looking for. The colour will definitely let you know in which context you are.
  7. M
    @Coen yeah... btw i saw that everything in the UI can be customized with a similar python command, so it is awesome :-)
    It needs a bit of digging around in order to know the right property, but it is doable ...
  8. A
    It's not just you hahahha, this is a great suggestion
