BoundingBox issues
  1. P
    Hi everyone,
    I am trying to get bounding box dimensions of elements in my IFC files. I use the following code to achieve this:
    def get_bbox_local(file, entity):
        settings = ifcopenshell.geom.settings()
        elements = file.by_type(entity)
        for element in elements:
            shape = ifcopenshell.geom.create_shape(settings, element)
            geometry = shape.geometry
            vertices = get_vertices(geometry)
            bbox = get_bbox(vertices)
            min_coords, max_coords = bbox
            # Extract individual min and max values for x, y, z
            minx, miny, minz = min_coords
            maxx, maxy, maxz = max_coords
            # Calculate dimensions
            length_x = maxx - minx
            width_y = maxy - miny
            height_z = maxz - minz
            # Store into DataFrame
            data = {
                'Length_X': [length_x],
                'Width_Y': [width_y],
                'Height_Z': [height_z]
            df = pd.DataFrame(data)
            print(df)
    Unfortunately for some reason objetcs not parallel to XYZ global coordinates get wrong dimensions. This is however happening incosistently - e.g. IfcDoors and IfcWalls always turn out correct, but IfcSlabs and IfcBeams don't. Does anyone have any idea how this could be solved?
  2. M
