File format
  1. R
    Hi all,
    How can I build a new file format?
    And how can I register it globally?
    And if we have an specific file format, it should have specific compiler or something like that to read my file in different software?
  2. B
    Are you talking of a patent? Those who are programmer can give you better advise. But I think you do not register it, unless you want a patent. if you want a format to share data with other software, you should use an already existing open format.
  3. R
    @bitacovir I have to search and find an article that was talking about how to build your own file format, and then register it globally.
    For instance Dion built a file format called .mpass so how can I build such one?
  4. M
    Anybody can create any file, even with a text editor, and rename the extension to whatever they want, such as .mpass to create a new file format. There is no need to register it.
    The .mpass file I created is simply a .json file - it is plain text and contains JSON data. So in fact what I did was establish a "schema", which uses an existing plaintext syntax - a convention of what data might be included in the JSON file.
    People create new file formats all the time. On Linux, file extensions are simply a convention, you can name it anything, some people don't even bother giving a file extension.
    @bitacovir is correct.
  5. W
    When I searched this forum for the file format SDNF (Structural Detailing Neutral Format), I could not find any entry yet. It may be that there is no use of the format in the open source world because it technically 'owned' by intergraph but it is very good for transporting structural steel models from one platform to another while keeping everything intact. With it steel sections exported from Tekla Structures ended up as (native) steel beams in Revit as well as OpenBuildings Designer. Maybe there already is a script out there that can parse these text files.
  6. B
    @wmi I wrote a tool for converting mesh geometry into SDNF steel plate models (in my File::DXF perl module somewhere if anyone needs it). I never had a use for reading SDNF, but the format is straightforward.
