Is there a Blender tool, that could quickly reset the mesh like the following, to just the exposed outside surfaces?
I tried the shrinkwrap modifier, but doesn't seem to work.
...other than the Boolean Union modifier.
Did you try the Remesh modifier? The downside is that it can create a lot of geometry.
I have, i couldn't get it to work, unfortunately.
Not the quickest way, but this can be done with Topologic:
Also the 'Topologise' modifier in the Homemaker add-on will do this (though you will have to delete internal cut faces afterwards).
