IFC Surface Style Missing
  1. L
    Hello, I’m using Blender BIM 230902 in blender 3.6, I got the problem that if I modified an element in edit mode the IFC style will lose when I save, when I reopen the file, it only contains the material, but the IFC style property is missing. I tried to reassign the material with the IFC style created but every time I save the process repeat, I have geometry with grey colors only.
    The IFC original file is created from inventor with the help of a plugin called BIMDeX.
  2. T
    can you share the IFC file, or a parred down version of it? And point us to the object you're trying to change?
  3. L
    Sure, here are the example files.
  4. T
    This is not intuitive, but here's a few steps to correct...
  5. L
    Thanks this help a lot! :D
