How do you remove an External Surface Style?
Is the only way, to bim.unlink_styleor bim.remove_style?
If you unlink a style, how would you attach the same style again, or different one?
I assume bim.unlink_style removes the style's association with the ifcmaterial and bim.remove_style removes the style all together from the IFC file. Correct?
