Can we search/filter by IfcPresentationLayerAssignment in BlenderBIM?
Nope. Great idea! Would you like to try and implement this? It's not too tricky.
Can you search/filter by IfcElementAssembly? That is, is it possible to select all the objects inside a IfcElementAssembly aggregate?
With the aggregate selected, you can select all children. In the geometry panel under presentation layers, you can also select all elements belonging to a filter. So the functionality is there... just not in the "search" panel.
Is there a facet selector yet for aggregates, so you could put this in the 'exclude' EPset_Status attribute, for example?
Not yet, I have a mental list of a variety of facets I want to add, including "group" (which includes system), "layer", and "parent" (includes aggregate, nest, and contained in).
