by Magnus952 on 12 Oct 2023, edited 13 Oct 2023
Hello.
I have installed blender 3.6.4.
Then i want to install the blenderbim add on. Im currently trying to install blenderbim 231012.
When i try to install it, im not getting the import-export blenderbim. I only get system:blenderbim.
Have anyone got the same issue?
by theoryshaw on 12 Oct 2023
I think this is indented, and has been changed awhile ago.
With #NativeIFC, it's no longer a import/export process--as BB is writing/reading directly to the IFC file.
Thus, BB now opens and saves to an IFC file...
video:
video:
I dont have to import IFC file like you show in the video either
Dumb question, did you enable the plugin?
Or if you still don't see Open IFC Project, download the latest BB here: https://blenderbim.org/download.html
nevermind. I see you have a later version..
should still work, though.
weird. I dont understand why it dont work
by Moult on 13 Oct 2023
Seeing "System: BlenderBIM" is normal. It was changed in the last release. It is also normal not to see anything in your import/export settings. You can just open / save IFCs:
You're probably looking at pictures / video tutorials that are outdated (and yes, our official documentation tutorial is outdated and we need to update it!)
It looks like your add-on is not enabled. Can you check that it is enabled in the preferences > add-ons tab?
by Magnus952 on 13 Oct 2023
I got the same as you now. i forgot the enable it this time after removing it xxx times.
Thank you.
