The door is not visible in teh drawing
i bet the 2d door swing is buried in the slab... just slightly. Try raising it up slightly.
thank it very helpfull
but there is a new problem, the brick pattern is not visible
Hey Sahul try use lower case ' brick ' not ' Brick '
thanks @Ace it worked
How to copy grid and dimension to each Level Plan Drawing..?
can anyone answe it. or this feature is not available in blenderbim...?
See this answer for grids..
and
see this answer for copying other annotations.
