About IfcPatch (ExtractElements) in BBIM 230902
  1. A
    Hi all,
    I'm testing IfcPatch (ExtractElements) in BBIM 230902 (with a particular user pset property) without success.
    I try the same (with the same ifc file) in BBIM 230701 with good results. The query I use is like this:
    IfcElement[PSET_Name.PSET_Property ="EST"] and get expected objects.
    In BBIM 230902 results are good if in query fiels on IfcPatch tab I put only the class (that is ifcWall, IfcSlab, etc.). When I add user pset properties, result file is created but without elements.
    I tryed put commas in query (that is IfcElement["PSET_Name"."PSET_Property" ="EST"] ) with the same result.
  2. T
  3. A
    @theoryshaw thanks for the comment,
    this query worked in BBIM 230902:
    IfcElement, PSETName.PSET Property=EST ("EST" is my search strint)
  4. B
  5. A
    @BimETS,
    some samples here works for me ( ACATIdentificacio.ACAT.... are user psets):
    IfcBuildingElementProxy, ACAT_Identificacio.ACAT_I3-TipusNom=/Lin*/
    IfcElement, ACAT_Identificacio.ACAT_I4-Subsistema=OL + IfcBuildingElementProxy, Name=/Base_E-[0-9]{1}/
    IfcElement, ACAT_Identificacio.ACAT_I4-Subsistema = OL + IfcBuildingElementProxy, ACAT_Identificacio.ACAT_I4-Subsistema=999999
    Make sure that the pset values ​​are correct (it is really "False", not 0) and try with a more generic element (IfcElement) to see if the problem is caused by IfcTrackElement
  6. B
    Thanks @avico, I show you my tests:
    IfcElement,ETS_U_SEG.ETS_U_U_SEG_01_Executed=False, and it does not work.
    IfcElement,ETS_CLA.ETS_CLA_06_CodFuncRIH=‘FUN.VIA.030.030’ and it doesn't work either.😩
  7. A
    In you can share your model I can try. Now I'm using BBim-addon_24-06-02
  8. B
  9. A
    I think the problem comes from the fact that the property "ETS_U_SEG_01_Ejecutado" is defined as IFCBOOLEAN and the syntax will be different (I don't know which one) or it simply doesn't understand it.
    In the properties defined as IFCTEXT the extraction works correctly:
    IfcElement, ETS_CLA.ETS_CLA_07_CodFuncRIH=/FUN.VIA.030.030/ extract the sleepers
    IfcElement, ETS_CLA.ETS_CLA_07_CodFuncRIH=/FUN.VIA.010.010/ extracts the rails
  10. B
    Thank you very much for your help. I was desperate
  11. B
    @avico I did a test with the ifcBoolean and you have to put true or false in capital letters. I did a test with the boolen and you have to put TRUE or FALSE in capital letters. And it works!
    IfcElement, ETS_U_SEG.ETS_U_SEG_01_Ejecutado=FALSE
