Adding custom representation in elevation view
  1. S
    How can i use the trace outline in a elevation or a section view? Tried Plan/Body/ELEVATION_VIEW, Model/Body/ELEVATION_VIEW and i did get the outline but in the xy plane, basically in plan view. The Model/Profile/ELEVATION_VIEW does gives me the correct outline, but does not print, it keeps printing the tesselation, not the outline it just created
  2. T
    Good question. It's a very hacky way, but you can rotate the origin 90 degrees, and then do the 'Trace Outline', and then rotate the origin back when done... you probably will have to rotate the outline too.
    Would be a good feature request to prompt the user which direction, and from where, the 'Trace Outline' is taken.
    Would be somewhat in line with this feature request: https://github.com/IfcOpenShell/IfcOpenShell/issues/3782
