How to add qto
  1. C
    Hi I'm new to all this IfcOpenShell python.
    I would like to add the GrossFloorArea to all the IfcSpaces that do not have this property. This property needs to be inside Qto_SpaceBaseQuentities.
    If the IfcSpace does not have Qto_SpaceBaseQuentities then I would like to add Qto_SpaceBaseQuentities and GrossFloorArea to that IfcSpace.
    My final problem is to save these pset/qto(?) into a new IfcFile. Hope some of you can help me, thank you.
    My current script looks like this
    import ifcopenshell
    import ifcopenshell.api
    model = ifcopenshell.open(r"C:\ifcopenshell-python-311-v0.7.0-dadcbe6-win64 (1)\model\model.ifc")
    import ifcopenshell.util.element
    spaces = model.by_type("IfcSpace")
    samlet_gross_floor_area = 0.0
    for space in spaces:
    try:
        pset = ifcopenshell.util.element.get_pset(space,"Qto_SpaceBaseQuantities",should_inherit=False,prop="GrossFloorArea")
        qto = ifcopenshell.util.element.get_pset(space,"Qto_SpaceBaseQuantities",should_inherit=False)
    except TypeError as e:
        print("Space does not contain Qto_SpaceBaseQuantities")
        continue
    try:
        print(pset)
        samlet_gross_floor_area += pset
    except Exception as e:
        ifcopenshell.api.run("pset.edit_pset", model,
                            pset=model.by_id(qto["id"]), properties={"GrossFloorArea": 120})
        print("Added grossfloorarea")
    model.write(r"output.ifc")
