Evening. I would like to describe the need for slanted wall functionality in this post. I will describe what i have done, and hopefully it points out the need for this functionality.
I am trying to add a slanted wall between two known lengths by two separate walls, which i know the lengths. However, there are no quick tools for this.
I therefore added a new wall which i am to manipulate with snapping features of line (or vertex point).
When i manually do adjust a wall, it will look somewhat like this:
When now assigning a door, the entire geometry of the wall is forced to its default starting position.
Upon further investigation, if i rather adjust the wall with the blender rotate function, and thus rotate it a bit:
And now add a door, it is successful and does not result in the same error as shown previously.
I would like to know if it could be a potential feature to add a slanted wall between two "master walls". As i can see, it is an irritational editing needed to make the slated wall with the rotate function work. To do this, i would recon i know the slanted walls exact lenght beforehand to easly snap it, however if i want a Mitre cut on the edge, i cannot do this as it then mean i have to adjust the edges with blenders edit functionality.
