by tsvilans on 19 Nov 2023, edited 5 Apr 2024
I watched the very helpful video tutorials and poked around the code, but I can't seem to find out how to add more grid axes to an existing grid. Duplicating the IfcGridAxis object does not work - it simply does not duplicate anything - and there is no entry for IfcGrid or IfcGridAxis if you want to assign an IFC class manually...
Is this still to-do or am I missing a key panel/tool/workflow?
Thanks!
by theoryshaw on 19 Nov 2023, edited 19 Nov 2023
+3 votes
Welcome. In BB preferences, uncheck the following...
Thank you! That does it :)
by steverugi on 18 Feb 2024, edited 18 Feb 2024
Hi @theoryshaw
is the Grid somehow not working in BBIM with Blender 4.x+?
after setting the axis (number and spacing) by pressing F9
whatever change I apply (since grids have often more than one spacing value) to it the .ifc file keeps the original arrangement
also, if I try to shift+D one axis in Object Mode it pops up the following :
if I do it in Edit Mode it looks fine but the added axis is not saved..
edit
now it's working, provided I do not change their number, axis can be adjusted
please disregard my post, thanks
D
by DiegoAlvarez on 5 Apr 2024
@steverugi Hi, please excuse me, how do you accessed such menu (U Spacing, Number of U Grids, V Spacing, Number of V Grids) for editing the grids? I tried to access to it pressing F9 or checking on the object menu, but I could not find it. Thank you in advance.
by steverugi on 5 Apr 2024
after added them the key F9 is only possible to use to modify grids (to some extent..) until you use a different command
for later editing you need to deselect the box here:
I personally find the grid thing in BBim a bit tricky, I usually set all needed linex when I use it the first time, I struggle to add or remove them at a later stage, there might be something I miss here..
by theoryshaw on 5 Apr 2024
i too still can't delete gridlines: https://github.com/IfcOpenShell/IfcOpenShell/issues/4345
There's this problem too: https://github.com/IfcOpenShell/IfcOpenShell/issues/4344
