I'm after some help please in applying a surface pattern to a (floor) material, so that a cross hatch or similar will show up on the created svg drawing. Thanks for any assistance.
Do these videos help?
Thank you for your reply theoryshaw. I will have to study the videos closely later.
I am a building designer, with no code knowledge. I am proficient with BIM applications like Revit and ArchiCAD. I was looking for a UI way to assign a pattern file to a surface. I might be missing something, but with my large complex models, I am not sure how I would find the relevant code in a large file with the inspect option.
Thanks again, I'll continue my quest, and when I look closely at your videos, I might learn something!
Yeah, unfortunately there's no familiar interface for applying surface materials yet. If you're familiar with CSS and SVG (which aren't too hard to learn) you can hack your way through. :)
