BlenderBIM installation problem
  1. B
    I installed latest Blender LTS 3.6.5 and latest BlenderBim v0.0.231104
    When I try to activate the AddOn in Blender I get the following message ...
      File "C:\0_BHA_privat\progr\PortableBlender\3.6\scripts\modules\addon_utils.py", line 333, in enable
        mod = __import__(module_name)
      File "C:\Users\BHA\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\blenderbim\__init__.py", line 41, in <module>
        import blenderbim.bim
      File "C:\Users\BHA\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\blenderbim\bim\__init__.py", line 25, in <module>
        from . import handler, ui, prop, operator, helper
      File "C:\Users\BHA\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\blenderbim\bim\operator.py", line 37, in <module>
        from blenderbim.bim.ui import IFCFileSelector
    ImportError: cannot import name 'IFCFileSelector' from 'blenderbim.bim.ui' (C:\Users\BHA\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\blenderbim\bim\ui.py)
    cheers Bernd
  2. B
    file C:\Users\BHA\AppData\Roaming\Blender Foundation\Blender\3.6\scripts\addons\blenderbim\bim\ui.py ist there and a class IFCFileSelector is in it ...
  3. B
    same in in Blender Python console ...
    PYTHON INTERACTIVE CONSOLE 3.10.13 (main, Oct 10 2023, 08:34:31) [MSC v.1928 64 bit (AMD64)]
    Builtin Modules:       bpy, bpy.data, bpy.ops, bpy.props, bpy.types, bpy.context, bpy.utils, bgl, gpu, blf, mathutils
    Convenience Imports:   from mathutils import *; from math import *
    Convenience Variables: C = bpy.context, D = bpy.data
      File "<blender_console>", line 1, in <module>
  4. A
    @bernd Hello! Just tested the latest build on Blender 3.6.5 - it's enabling without errors.
    Are you sure it's the full error traceback? There might be some other errors prior to that one in system console (can be enabled from Window -> Toggle System Console) when you enable the addon.
  5. B
    Just wanted to say with Blender 3.6.10 protable and BlenderBIM v0.0.231104 the problem has cleared away
