@theoryshaw said:
Might be because the link or path to the IFC was broken.
Maybe try linking it back to it like this.
In general, especially if you're a relatively new BB user, it's best practice to not even save the .blend file. It 'can' be done saving both the .blend/.ifc at the same time, but there can often times be syncing errors. It's best practice to just open and save the .IFC only.
Thanks so much for having a look at the files. The link path to the IFC seems fine on my end.
Thanks for the advice on using the IFC file only, I'll be sure to do that in future. I originally went down the combined blend/ifc path because I was familiar with shader & UV editing in blender and didn't see how to save the materials, but I think I now see that can be done in IFC using IfcSurface Styles.
@theoryshaw said:
Would suggest using 'Shift + E' to extend a wall to a roof. That way you don't have to mess around with voids.
You can use 'Shift + G' to regenerate the wall if you move the roof slab for example.
I was aware of using "Shift + E" to extend walls to the roof, but hit a problem when I had a couple of walls that needed to extend to 2 separate roof slabs.
@theoryshaw said:
I did notice, however, if you open just the .ifc itself, the file doesn't open at all... well on my end anyway.
If that's the case for you as well, I would open a bug report here: https://github.com/IfcOpenShell/IfcOpenShell/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
Yes. the IFC file opens on my end but shows no objects. All my types can be seen in the BlenderBIM tools, and other things like Profiles & Materials are there. I will report a bug. Thanks for the link.
