Elemented wall the good way ?
  1. B
    Hi everyone, i have this case to deal with and i want to do it properly.
    This is a wall made with bale of straw and that will look like barely like this:
    I'm wondering how should i model that correctly to respect IFC standard.
    I started by defining the straw units as buildingElements - the concrete part as a ifcwall and wooden beams as well. I wanted to go on with defining an aggregation into IfcElementedWall to group elements into a sigle unit as a wall. But i encounter issues doing this, it won't aggregate. It might be the fact that i shouldn't put an IfcWall into an IfcElementedWall. I confess i don't really know what i should do in this particular case.
    Specialists help would be much appreciated.
    Thank you
  2. M
    Hi bdamay, i'm not a dedicated Ifc specialist so my answer might not be correct...
    If your components have to be nested, you can have a look at IfcWall with IfcMaterialLayers.
    There is no hint that those layers necessarily are verticaly oriented.
    LINK Ifc 4.3 docs
    Edit:
    For the IfcWallTypeEnum "ELEMENTEDWALL"
    LINK Ifc 4.3 docs
    BR
    Marcus
  3. B
    @mcnill Thanks taking the time to answer.
    I took a look on the pages you mentionned and it appears to me that it might not possible to model IfcWall as i intended to. I mean by defining individually every part of it and regrouping it in an aggregation.
    As you said, layers might not be vertical but in my understanding of what i read of spec they are still layers that should be uniform along the Wall. (Am i right ? )
    It is not quite what i want to do as i want to keep track of each individual bale of straw in the wall.
    Quite some time ago, I remember i viewed a BlenderBim demo (in early stages i think, cause i didn't manage to find it today) where a brick wall was modeled with each individual brick in an array plus various wooden beams forming parts that were grouped together in a single Wall (I think @Moult did it but i'm not sure, and i'm not that sure he was doing what i say, my memory fails sometimes)
    Thanks for helping
  4. B
    @bdamay I think you can model a wall any way you like. You can create a 'straw bale' type (ifcbuildingelementproxy or whatever), stack lots of instances and aggregate it into a wall.
    I believe that you can add windows and doors to the wall aggregate, and the openings will cut the stacked bales (though I haven't tried this myself yet).
  5. B
  6. B
    I will try it again with buildingElements - may be i didn't do it the right way before. May be i shouldn't try to aggregate a wall inside another.
    That would be super cool ! (But i won't use it here - there are no windows...)
  7. J
  8. B
