by steverugi on 1 Feb 2024, edited 1 Feb 2024
when using the grouping and filtering feature I need to select two types at the same time
in my case beams named BEM-02 and BEM-06
I can select them separately using the Type filter but can't figure out how to do for more than one
I tried + but didn't work
thanks for the help
by Moult on 1 Feb 2024
Add a second search group :)
Hi @Moult
I tried within the same Search Group but thanks to you I just realized that can be more than 1, and it worked like a charm :)
cheers
using two search group it generated the following query
IfcBeam, location="2-Roof1", type="BEM-03" + IfcTypeProduct, IfcProduct, type="BEM-07", location="2-Roof1"
is there any chance I could use the same in the Query filter? it would be much faster a method instead of duplicating it for every type
it offers 2 fields, not sure how to use it, thanks
