Hi @Andrej730
I've done a simple test to create a mirrored profile from a u-profile and assign it to a beam type.
This is my code below
I'hv also shared the error message on opening the ifc file.
Is the shape creation for IfcMirroredProfileDef failing?
I'm also attaching the test ifc file fyr
import ifcopenshell
path = '/home/arun/Desktop/mirror_test_u.ifc'
f = ifcopenshell.open(path)
beam_type = ifcopenshell.api.run('root.create_entity', f, ifc_class='IfcBeamType')
u_profile = f.by_type('IfcUShapeProfileDef')[0]
u_profile_mirrored = f.createIfcMirroredProfileDef()
u_profile_mirrored.ProfileType = 'AREA'
u_profile_mirrored.ParentProfile = u_profile
material_set = ifcopenshell.api.run('material.add_material_set', f, name=None, set_type='IfcMaterialProfileSet')
ifcopenshell.api.run('material.add_profile', f, profile_set=material_set, material=None, profile=u_profile_mirrored)
ifcopenshell.api.run('material.assign_material', f, product=beam_type, material=material_set)
f.write(path)
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/bim/module/project/operator.py", line 642, in execute
return self.finish_loading_project(context)
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/bim/module/project/operator.py", line 657, in finish_loading_project
bpy.ops.bim.load_project_elements()
File "/home/arun/Apps/blender-4.0.1-linux-x64/4.0/scripts/modules/bpy/ops.py", line 109, in __call__
ret = _op_call(self.idname_py(), kw)
RuntimeError: Error: Python: Traceback (most recent call last):
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/bim/module/project/operator.py", line 740, in execute
tool.Project.load_default_thumbnails()
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/tool/project.py", line 54, in load_default_thumbnails
bpy.ops.bim.load_type_thumbnails(ifc_class=ifc_class, offset=0, limit=9)
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/tool/ifc.py", line 207, in execute
IfcStore.execute_ifc_operator(self, context)
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/bim/ifc.py", line 341, in execute_ifc_operator
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/bim/module/model/product.py", line 389, in _execute
if tool.Model.update_thumbnail_for_element(element):
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/tool/model.py", line 780, in update_thumbnail_for_element
tool.Profile.draw_image_for_ifc_profile(draw, profile, size)
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/tool/profile.py", line 34, in draw_image_for_ifc_profile
shape = ifcopenshell.geom.create_shape(settings, profile)
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/libs/site/packages/ifcopenshell/geom/main.py", line 210, in create_shape
ifcopenshell_wrapper.create_shape(settings, inst.wrapped_data, repr.wrapped_data if repr is not None else None),
File "/home/arun/.config/blender/4.0/scripts/addons/blenderbim/libs/site/packages/ifcopenshell/ifcopenshell_wrapper.py", line 1817, in create_shape
return _ifcopenshell_wrapper.create_shape(settings, instance, representation)
RuntimeError: Token * at offset 3,316 invalid instance name
Location: /home/arun/Apps/blender-4.0.1-linux-x64/4.0/scripts/modules/bpy/ops.py:109
