by bdamay on 14 Feb 2024, edited 15 Feb 2024
Hi everyone,
I got confused by the way Shift E is acting between walls an slab. It seems that shift E creates a "dynamic" boolean operator on the wall (see img below). That's fine until it seems only one boolean (HalfSpaceSolid ?) can work at a time.
I found a workaround by setting the boolean to "manual" and repeat the shift E afterwards and resetting to manual. Seems to work fine.
But i'm wondering if this is right to do so , is it ?
or is there something else i should understand better ?
Thanks
by theoryshaw on 14 Feb 2024
+3 votes
Currently not possible to 'extend' one wall to multiple roofs...
https://github.com/IfcOpenShell/IfcOpenShell/issues/3081
As a work around, i do a void like that...
by bdamay on 14 Feb 2024, edited 14 Feb 2024
Hi @theoryshaw thanks for your reply. I understand that what i do with turning my booleans to "manual" is not the right way is it? I'm finally able to have my two cuts quite neat that way, i don't understand why would that be wrong (see below what shows when i turn boolean to visible) ? I may miss something...
I also havn't completely understood how i could duplicate my slabs into voids and find it a bit tedious to redraw a void the exact same shape of my roof.
Thanks again
Here's an update of my gif. The one before was not that clear i think . It seems that setting the boolean created by shift E as "manual" has made it permanent in some way... i can then redo another one. Why would this be wrong ?
by steverugi on 14 Feb 2024
interesting solution
I would normally split the wall into 2 and extend them against each roof slope
For me, i've found HalfSpaceSolid booleans a little buggy, especially when you miter/butt walls at corners, so i don't use them that much.
Yes i noticed something like that as well. Need to mitre before applying boolean. Or the other way around, i don't know... i'll look into this.
Splitting walls make some additionnal lines in the plan , isn't it? How do you get rid of these ?
Splitting walls make some additional lines in the plan , isn't it? How do you get rid of these ?
I use BBIM for converting 2D DWG into models to extract quantities, I haven't used it for professional printouts yet, only played a little with it
I thought wall seams when printing was sorted out by now?
by theoryshaw on 15 Feb 2024
they 'meld' in plan, but not in elevation.
https://github.com/IfcOpenShell/IfcOpenShell/issues/3742
by steverugi on 15 Feb 2024
thanks @theoryshaw
I am yet to adventure in the printout territory, however on top of walls I also use an IfcCovering layer of 2cm for outside plastering, which is kind of tedious due to openings.
Not sure if it's the right way of doing it, but atm I clad the whole lot mainly because I don't know how to deal with layer set in columns, slabs, and beams, where I don't have the the wall plaster skin to cover (If I were to use layer set in walls to include plaster)
As soon I as get enough proficient with the quantity thing I am going to move to documentation :)
by bdamay on 15 Feb 2024, edited 15 Feb 2024
Thank you for this information.
Well even if it was melted, (with all respect to @steverugi) i think i prefer not to split walls that i consider being one wall. I guess i need to try the void way you mentionned earlier.
Is it possible to duplicate an element as a void instead of having the void cube that you need to redraw? (I think i saw something like this somewhere but i can't recall where i might have dreamt it)
That said, even if buggy, i kind of like the HalfSpaceBoolean approach as it seems to be the way i think about it "The wall geometry is cut by the roof and above". I think, from a user point of view in an ideal world, one shouldn't have to create additionnal geometrys to deal with this.
Have a good day
Can you not use one opening (void) for multiple elements ?
I may be off of your topic about what you say about coverings but, i tried and it didn't quite work. I apparently can't select more then one element to apply th void on.
Are you talking about writing some documentation ? on the wiki or blenderbim.org documentation ? (or may be it's simply IfcDocumentation :-))
If i were may be a bit more experienced with BlenderBim, i surely would like to give writing doc a try (on matters like cutting walls for example). I understand a lot of material is inside the forum, some in the live chat, it is sometimes a bit hard to find.
no, I don't thing it's possible
say you have a wall with some covering/plaster, to the best of my knowledge you have to repeat the void (window/door is automatic but can't apply to covering altogether), but I might have missed something..
I meant documentation as in drawing printouts but I would love to contribute to the Wiki one day
+3 votes
There's (2) different ways. :)
FYI, I made a mistake in that video, don't have the window, 'inside' the aggregate.
+4 votes
1st method
this is a wall, net and gross areas are the same 15.157m²
this is a plastering cover, area is the same as the wall
as you suggested I add a window on the wall (0.68m²):
after recalculating the quantity I have the following net area 14.617m²:
I aggregate wall and plaster:
I select window and assembly
I apply void to the assembly
and the plaster nicely shows the void
recalculate area..
and all seems very much OK ! thanks
PS GrossArea of plaster seems not to be what expected but it's good enough for me
