Elements only appear once the project is saved
  1. R
    Attached is a screen view, showing how elements aren’t visible until the project is saved. The IFC file is attached to. Can somebody help with this problem or advise/show how I can clean my IFC file so that all elements are visible when the project is opened?
    Thanks, in advance
  2. C
    Yes, you're supposed to put your elements inside a Spatial Container, e.g. an IfcBuildinStorey.
    What you could do is the following
    Add empty -> Convert it to IfcBuilding
    Add empty -> Convert it to IfcBuildingStorey
    Move all the Ifc Elements underneath the IfcBuildingStorey
    I did it for you, see attachment. ✅?
    Dit is piekfyn?
    When you open it in BIM vision it automatically creates a log of which elements are not spatially contained.
