Surface model, coloring
  1. M
    Hi guys. I'm trying to figure out this part.
    Any ideas for a clearer picture? How does it work? The ultimate goal would be to make it part of the BlenderGIS addon as option.
    Coming from this briljant recording on a older Blender release.
    Thanks!
    Hans
  2. M
    Managed to get clearer shots. So far, so good.
    Added a IFC file to be tested
    Texture coordinates > objects
    RGB Curves > color
    HueSaturation Value > Color
    BrightContrast>Color
    ColorRamp >Color
    Emission
    Material output, Surface
  3. C
    Hi...no colors are coming in. The Surface itself is being represented.
  4. R
    I would rather start from Generated in Texture Coordinate, plug the mapping vector in a separte XYZ node, then plug the Z value in the color ramp
  5. M
    Do you have a file in which this is used? I want to learn this but it's not that easy to understand what you talk about.
    I attached a IFC as sample. You would need to save it as Blenderfile
    I managed to get this. But shading is not what IFC colors.
    The saved view tool doesn't seem to work in the shading mode with geodata far off.
  6. M
    How does one save shaded collored meshes to IFC?
  7. R
    Sorry, I didn't understand that you wanted to save it in IFC. I don't know if you can save procedural textures
  8. B
    My opinion is that you cannot. AFAIK
  9. M
    Would be nice as visual technique. ifc site in grey is hard to see the diffrences in heights. Will try dwg.
  10. G
  11. B
    @Gorgious said: or bake the colors to a texture map and link it as a style.
    Interesting - i didn't know about textures in ifc - i'll take a closer look
  12. G
    AFAIK you can setup textures in IFC but the actual rendering depends on the software implementation, so YMMV.
