I try to make a door made from extruded custom arb. profiles. For this I tested rotating the profile (currently a IfcColumnType, as I don't know the proper way to make this as a doortype). This works fine, but when I go into edit mode and back the rotation resets to default position.
I tried applying transformation, but then something goes wrong and I got the #instance not found error with every action. (After a reload of previous save this didn't happen again, but applying resets it to default and origin point) This error shows up quite regularly though.
So in short:
How to save the rotations of the extruded profiles?
What is the correct way to make e.g. a doorframe with extruded profiles?
-How to make a path with multiple vertices to extrude the profile along?
- How to resolve the #instance not found error if encountered? Or should I just reload file and hope it doesn't show up.
Thanks!
