Copy and Paste from one IfcProject to the other
  1. O
    Hi, what is the appropriate workflow to copy an element from one IfcProject to the other.
    I once saw a short video by @theoryshaw demonstrating how to copy an element from one ifc file to the other.
    I have not been able to find an easy way to copy and paste ifc elements between different project but I hope there must be a more streamlined approach.
  2. A
    If you need to copy type/material/profile you can add second file as a library and append the elements:
  3. S
    thanks @Andrej730
    but I wonder how to copy/paste Ifc elements (instances, not their type) from one project to another, if there is a way
  4. O
    Noted @Andrej730 but I don’t need it through the Project Library but a conventional copy and paste of instances just as @steverugi clarified it. A real-time interface approach. If I remember was it something like “Append” and the GUID that were used?
  5. A
    I don't think copy and paste is supported now, even copy and paste in the same BBIM session will make pasted element unlinked from IFC for safety.
    Added a new option to append elements from the library - https://imgur.com/a/yASjbs8 that should help. It probably will be moved elsewhere later on to allow adding occurrences in more visual way and less confusing for occurrences sharing the same names.
  6. S
    thank you @Andrej730
    Added a new option to append elements from the library that should help.
    super, I think it does the trick
    much appreciated
  7. A
    I've added similar option for appending elements from linked IFC files - https://imgur.com/a/phPcKSo. It should be much more versatile and currently will be the main way for appending occurrences.
