Connecting Spaces of a Stair
  1. A
    I was trying to find connected spaces using IfcOpenShell. But I couldn't find a way to extract the spaces connected by a stair. I am using the FZK Haus as the sample file. I have tried the geometry tree approach and was able to find the bottom space connected but not the top space.
  2. A
    Hi! Can you please show the code that didn't worked?
    Just tested the code below with bounding box selection:
    import ifcopenshell
    ifc_file = ifcopenshell.open(r"AC20-FZK-Haus.ifc")
    import multiprocessing
    import ifcopenshell.geom
    from pprint import pprint
    def check_intersections(ifc_file):
        tree = ifcopenshell.geom.tree()
        settings = ifcopenshell.geom.settings()
        iterator = ifcopenshell.geom.iterator(
            settings, ifc_file, multiprocessing.cpu_count()
        if iterator.initialize():
            while True:
                tree.add_element(iterator.get_native())
                if not iterator.next():
                    break
        element = ifc_file.by_type("IfcStair")[0]
        pprint(tree.select_box(element))
    [#59290=IfcSlab('2RGlQk4xH47RHK93zcTzUL',#12,'Slab-033',$,$,#59253,#59286,'DA0A17AC-B773-47AC-99-C5-D390C73AD5CC',.FLOOR.),
     #33774=IfcSpace('0Lt8gR_E9ESeGH5uY_g9e9',#12,'5',$,$,#33683,#33769,'Wohnen',.ELEMENT.,$,$),
     #59365=IfcOpeningElement('16PF6khT5_p$Z03P73inyv',#12,'Slab Opening',$,$,#59331,#59361,$,$),
     #39432=IfcMember('1qMEiq1Qz6guq8g1GCODiJ',#12,'Sparren-34',$,$,#39415,#39428,'3A999AF6-1C12-413A-89-B2-BF4A3CAEAD63',$),
     #39186=IfcMember('1NBDw_i_jD$u7IjvwmbPmx',#12,'Sparren-32',$,$,#39169,#39182,'62D6313A-B4FB-45BF-B3-97-10D01124A4F9',$),
     #39309=IfcMember('2DH$OLoObDkAtwqVzNdUnS',#12,'Sparren-33',$,$,#39292,#39305,'E4FF91FA-3AE7-4591-8D-5F-61E57F7BA5DE',$),
     #14502=IfcStair('38a9vdh9bF5Qg28GWyHhlr',#12,'Wendeltreppe',$,$,#502,#14498,'79A67A01-C95B-4209-86-9A-74983B65305C',$),
     #59753=IfcSlab('2IxUUNUVPB6Ob$eicCfP2N',#12,'Dach-2',$,$,#59716,#59749,'BD6D9414-37DF-40A8-88-40-301A32A9A5B5',.ROOF.),
     #49831=IfcRailing('0o5vgCKyTBzO5$QJcI2YDP',#12,'',$,$,#40768,#49827,'00000000-0000-0000-00-00-000000000000',.HANDRAIL.),
     #76214=IfcSpace('2dQFggKBb1fOc1CqZDIDlx',#12,'7',$,$,#76123,#76209,'Galerie',.ELEMENT.,$,$)]
  3. A
    @Andrej730 Thanks. This code is working. I think the part that is not working in my code is where i specified IfcSpace as include items.
                settings, ifc_file, multiprocessing.cpu_count(),  include=("IfcSpace")
    But if i remove the include parameter, it is working. Thanks again.
